Home > General (L494) > Has anyone fitted a deployable towbar |
I haven’t fitted one but I’ve had my bumper off & it looks fairly easy to do & the wiring should be there.
Fri Jun 12 2020 2:37pm |
You might also need this to operate the Towbar,it goes in the panel on the offside of the boot.
Fri Jun 12 2020 2:49pm |
pc1972 Member Since: 30 Aug 2012 Location: scotland Posts: 38 |
Hi tyrefitter , yes is that the switch that’s goes in the boot?, also some of the ones for sale on eBay are just the deployable towbar and some have a sguare subframe that the towbar structure would attach to? I won’t be towing a caravan ,it’s just for my bike rack , I think I’ll need a electric module as well ?
Fri Jun 12 2020 7:44pm |
I’m sure the square frame is for the full fat & not the sport,I haven’t seen the frame on mine but I will double check tomorrow.Ill also take a pick where the switch goes. Andy.
Fri Jun 12 2020 8:11pm |
Thanks tyrefitter that would be great 👍 |
Fri Jun 12 2020 8:22pm |
Fri Jun 12 2020 11:23pm |
Riverblanche that looks slightly different as the L494 fastens to the rear panel not to the chassis like the disco & L320,the L494 hasn’t got the chassis.Ive been under mine loads of times with having my own lifts & ive never seen the square frame.
Sat Jun 13 2020 7:37am |
Hi riverblanche thanks I’ll have a look 👍 |
Sat Jun 13 2020 10:12am |
Sat Jun 13 2020 12:06pm |
Ok thanks riverblanche👍 |
Sat Jun 13 2020 2:03pm |
The L494 does have that square frame,it bolts inside the boot. Andy.
Sat Jun 13 2020 2:18pm |
Thanks tyrefitter, do you know what LR mean by towing preparation, it was listed on mine but I’ve no towbar fitted ? |
Thu Jun 18 2020 12:12am |
Probably means wiring is there.I took a picture of the square frame & it fastens underneath where their is pre drilled holes in body.It goes round the battery case.
Thu Jun 18 2020 1:45am |
Hi tyrefitter I’ve looked under mine I’ve not got any box section 👎it has the predrilled holes so I’ll need to source that piece as well 🤔 |
Thu Jun 18 2020 11:23pm |
