![]() | Home > Technical > Red light |
I’m in a similar boat to you, new battery 7 to 8 months back and now the battery is on its way out. This is the second battery as the first with the same symptoms I have now lasted 9 months. I knew something was off when it was slow to turn the starter yesterday so popped it on the CTEK and today it was showing green...but wouldn’t turn over. So tomorrow I’m off to try and get it replaced again. It’s a YUASA which I thought were good but my experience of them is not brill, 2 On my Focus in 4 years and 2 on the Range Rover in 16 months. 2019 5.0 SC SVA (Current)
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 ![]() ![]() ![]() |
Hi Brit Plumber these cars drive great but i have to say its the most unreliable car i have ever owned, but having said that id possibly buy another one. good luck with your battery i am hoping mine is just a battery and still under warranty.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
U0132 is a loss of communication with the air suspension control module. There are 4 associated codes. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Hi RRSTDV8 many thanks for the reply i am just about to order a new battery as its low voltage when engine turned of 11 volts roughly could this be causing the problem with lost comms or should i start looking elsewhere
What does it show with the engine running? Is the alternator ok? 2012 SDV6 - it's missing a couple of cylinders
Hi with the engine running it hovers around 14 volts but battery goes flat after 36 hours so i am sure it has dead cell even though its only 6 months old as far a i know the alternator is ok no battery light on or faults come up new pump brake light switch etc
