Home > Wheels & Tyres > Adding TPMS?
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Adding TPMS?
Hello
Currently on a RRS 3.0 TDV6 Autobiography MY2013
Its without TPMS, is it possible to add without ridiculous expense?
Thanks in advance Thumbs Up
Post #599055 Mon May 18 2020 9:48am
The RRS1 system is pretty usless really, just as well off getting a decent aftermarket setup.
Post #599056 Mon May 18 2020 9:55am
abiopete
Cheers Col, any suggestions?
Do the RRS1's have it programmed in, its just a case of adding the monitors?
Cheers,
Pete.
Post #599057 Mon May 18 2020 9:59am
All the factory system does is flash a amber warning light on the dash indicating which wheel/tyre is low and only then if the pressure drops by around 25%. thats about it, it does nothing else.
Post #599058 Mon May 18 2020 10:08am
Brit Plumber
I’ve done a retro fit to my car, sensors are about £20 each and fit to the liner, receiver is about £20 to £30 and fits in the overhead console. Wiring is all present but either tied back or is plugged into a stowage. CCF edit can be a mare as there’s so many options and wheel sender units are a nightmare to. I still haven’t got it working properly, i.e. the car part of the system is fine but has a fault as it appears to be not communicating with the wheel senders. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #599915 Tue Jun 09 2020 10:06am
Brit Plumber
Well low and behold it started working today! No idea why, after it being fitted for at least 12 months. 2019 5.0 SC SVA (Current)
Post #599956 Tue Jun 09 2020 4:24pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
You will to niggle about the car more and then things that don't work will, nice cheap easy fix though.
Post #599991 Wed Jun 10 2020 9:01am
abiopete
Is it just the warning you get not actual pressure readings? L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #600082 Thu Jun 11 2020 3:13pm
Brit Plumber
Yep, no readings, just Tyre pressure monitoring available when you start the car and then a warning if a tyre pressure drops. I don’t know if it tells you which tyre but it should have that ability. I did think about retrofitting the 2014 disco 4 cluster which has the later EU legal requirement of readings however when I delved into it, I would have had to do a lot of work with the software to make it work. 2019 5.0 SC SVA (Current)
Post #600095 Thu Jun 11 2020 7:32pm
As I've said before all it does is flash a yellow warning and which wheel i.e. n/s/f, o/s/r etc. on the dash, that is it's total capabilities, no pressures, no temps even then on mine the pressure of the tyre will have to drop to around 25psi before you get any warning. If the ambient air temperature is high that also sets off false warnings. At best it could be described "better than nothing" just, taking into account it was nearly a £400.00 option one would have thought it would do a little more than that. Forgot to say it does say if set to light or heavy load when doing system check.
Post #600107 Thu Jun 11 2020 10:33pm
Brit Plumber
Well it stopped again yesterday. The system appears to work so not a loose wire. It just appears to lose comms. 2019 5.0 SC SVA (Current)
Post #600170 Sat Jun 13 2020 8:43am
Could try this, only listed at 1p on Amazon proably more reliable than the L/R system. Laughing
Post #600171 Sat Jun 13 2020 9:25am
