Home > Technical > All terrain knob pushed down any benefits ?? |
Terryok Member Since: 06 Jul 2019 Location: Kent Posts: 24 |
As above what's the difference with "knob up or pushed down" |
Tue Jun 09 2020 9:42am |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 536 |
Tue Jun 09 2020 2:52pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
your making that up!
Tue Jun 09 2020 3:51pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Haha - a joke I think - knob up means it is in the way but can be turned, down it is out of the way - there is no auto function on the OPs vehicle. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Wed Jun 10 2020 2:48am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Long time since had my TDV8 but I though pushed down it's permanently active and basically does it's own thing, when raised driver can manually control different settings, which is basically what Scrumps said I guess.
Wed Jun 10 2020 3:59am |
If in doubt read the manual 07MY RRS TDV6
Wed Jun 10 2020 5:57am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
No Col, not on the L320 - there was no "does its own thing" facility. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Jun 10 2020 6:19am |
Surely if it's permanently active it must allow it to do doing something, otherwise in might as well just be switched of when the knob is down. I guess it depends on how you interpret what it actualy says in the handbook, although automatic probably isn't the right description.
Wed Jun 10 2020 6:46am |
I think you are getting confused as TR cannot be turned off (unless there is a fault). This is normally the onroad setting and the computer runs everything - the other TR settings have to be manually selected - there is nothing automatic about it - all in the handbook - just checked.
Wed Jun 10 2020 7:44am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I didn't even know my knob could be pushed down... fnarr, etc
Wed Jun 10 2020 7:52am |
I didn't say it could be turned off, I said it was permanently active so it must be doing something in that mode. I also said automatic was probably not the right word to describe what it does do, but if it is controlled by computer with no input from the driver in that mode some may describe that as automatic operation. I think this is a debate that could just go on and on based on choice of words.
Wed Jun 10 2020 7:56am |
If no special programme is selected, then the system just runs the default road-biased traction control / DSC settings. Centre diff can come in to play too, I think, but obvoiously on tarmac it's very unlikely.
Wed Jun 10 2020 3:28pm |
I am sad to discover that my 59 plate knob does not retract
Wed Jun 10 2020 6:32pm |
