Home > In Car Electronics > 2012 (MY13?) Sat Nav Updates
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Autobiography1969 wrote:
OK,
So I emailed including my Vin Number
Hello I am looking to get the following update but not sure its right for my car
2019 LANDROVER GEN 2.1 SAT NAV MAP UPDATE USB NAVIGATION EUROPE
My VIN is SALLSAA**********
Can you tell me if this update on the sat nav is compatible?
Thank you
to;
https://www.satnavishop.co.uk/
rustymidgetman@sky.com
from
https://www.satnavupgrades.co.uk
Both do the same thing but slightly different prices.
Rusty has replied first,
yes you have gen 2.1 here is what you need
https://www.satnavupgrades.co.uk/2019-LAND...p122222095
Rusty
As said its a little more expensive but if the other place does not answer this will be the one I use..
Just as a note I have no affiliation with either business,
so please check for yourself and choose whoever you wish to..
Well I've just ordered the one from Rusty at £110 after he got back to me straight away.
Don't really fancy running the engine for 3 hours to do the update though, is there a way to keep the ignition on without it going to sleep? L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #599738 Fri Jun 05 2020 2:05pm
abiopete
Got the USB from Rusty, he estimated 2hr 35 mins, the RR estimated 3hr 5 mins and it actually came in at 2hr 51 minutes.
All went smooth no problems at all. Not used it yet will update if there's any issues.
Post #600132 Fri Jun 12 2020 11:27am
Autobiography1969
Hi Mate,
Did you go for a long drive, attache a battery charger or just leave it
on idle for the duration?
Really pleased it worked out for you.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #600136 Fri Jun 12 2020 2:03pm
abiopete
Had a Skype meeting so had it my car with the engine running and had a 1.5hr journey after. Didn't want to risk anything else as it puts itself to sleep after a certain amount of time.
I've had the update for a week but this was the first opportunity. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #600137 Fri Jun 12 2020 2:08pm
Autobiography1969
Thank you,
off to order mine now.. Wink
Ordered... Smile ===========================================
Post #600138 Fri Jun 12 2020 2:10pm
Autobiography1969
So did the update yesterday,
Started at 12:11;
Then it goes very quiet for 15 mins ish and then;
amount of fuel when started;
sat back and watched some TV on my phone, 25%
1 hour in and 30% Done
2 hours in an 70% Done
Finally Done, followed the final bits of info received from Rusty
Total amount of fuel used,,
Left the car for 30 mins and went back to see if it had worked, and fantastic, worked a treat..
Highly Recommend this place for all your SatNav requirements ===========================================
Post #602727 Tue Aug 04 2020 3:49pm
