Home > In Car Electronics > 2012 (MY13?) Sat Nav Updates
Autobiography1969
Hello all,
I have now decided as we slowly begin to see the start of the end of lock down that
now may be the time to update the SAT NAV in the RRS,
She was Manufactured in 2012 (unknown Date)
and First Registered 21/12/2012
Am I correct in thinking my system is the HDD 2.1 that needs the USB Download
that is used between 2012 & 2019 ish
I have found this place on the www that seems to have reasonable rating,
https://www.satnavishop.co.uk/2018-2019-la...-706-p.asp
I think I would go with the Map update sent by post + Activation code
option as it would give me less chance of messing it up..
Can anyone advise if I am correct and is there anything to watch out for when doing this ?
Thank you for your time.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #599595 Wed Jun 03 2020 11:41pm
On a MY13 car you will have the 2.1 gen system. The Usb stick was only used between 2012 and 2016 later vehicles used a different system, but not to saying the latest maps have not been added to a stick to use on the earlier 2012/16 cars.
col
Post #599600 Wed Jun 03 2020 11:50pm
Autobiography1969
Thank you Col,
swift reply as always,
I am just a little concerned about the 3 hours it takes to
complete, guess I better fill up before I start..
Any advise on what to avoid or not to do? ===========================================
Post #599603 Thu Jun 04 2020 12:05am
Yes, it did take a little over 2 hours to upload, last time I did mine left the car idling on the drive, cost more in petrol than the map cost Laughing it will start and stop if you wanted to do it that way but I preferred to do it in one go, probably make no difference but though it less chance of anything going wrong.
Post #599604 Thu Jun 04 2020 12:17am
Autobiography1969
Thumbs Up ===========================================
Post #599605 Thu Jun 04 2020 12:18am
mrluke
Also be very careful with it .
I updated mine and it kept error'ing . So i had to keep turning off and turning back on again
In the end , it looked like it worked, but i had no ability to search for any new postcodes.
I had to wait till a "Newer" update was avaliable and to flash that over top.
With all that being said.. it was pretty rubbish after the 2019 update. Liked taking me on 1hr+ detours.
Post #599618 Thu Jun 04 2020 9:07am
Autobiography1969
Thank you for the info guys,
I will update when I get round to it..
Thanks Again ===========================================
Post #599620 Thu Jun 04 2020 10:00am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
That's the map I used, I download onto my own USB stick which from memory was 4 .rar files which you expand onto the stick. You can expect the update to sit on 0% for quite a while then it heads to 100% quicker, I did it in one go. I was too impatient so didn't wait the 30 minutes shutdown (or whatever it says) after the update so I got a worrying black screen - just wait the time as per instructions before powering back up and all should be fine. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #599628 Thu Jun 04 2020 11:10am
Autobiography1969
I am fairly inept when it comes to electronics and stuff so I will be getting the
I guess the Map by post is already on a USB ready to go, ?
Then you just have the activation key relevant to your VIN number to
make it all work..
I will either have to waste a 1/4 tank of fuel or do it over several days with start
and stopping it when parked up..
Are there any better known suppliers or is this one good enough.. ===========================================
Post #599647 Thu Jun 04 2020 3:34pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I emailed them and they said it wasn't suitable for my car MY13 RRS1 L320, any idea if it is?
 L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #599651 Thu Jun 04 2020 4:46pm
Autobiography1969
Hi abiopete
Did you give a Vin number for them to check?
How old is yours, I know you said a MY13 but what what
the date first registered?
I may need to drop them a mail as well then..
Thank you.. ===========================================
Post #599652 Thu Jun 04 2020 4:49pm
abiopete
No just sent them that picture and got this reply.
First registered 15th April 2013, would love to be proved wrong let me know if you get a different answer i'll buy it straight away! L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #599653 Thu Jun 04 2020 4:53pm
Autobiography1969
OK will mail them and see whats said..
Thank you for the heads up.. ===========================================
Post #599654 Thu Jun 04 2020 4:55pm
insiorc
Not suitable? My RRS is a MY13 L320, built Nov 2012 and the update was fine. Below is a copy/paste from my order email. I updated in September 2018 but I assume LR are no longer updating our version as it's still the same 2018/19 map.
Your Order Details...
Description Item Price Qty Total
2018-2019 LANDROVER GEN 2.1 SAT NAV MAP UPDATE USB NAVIGATION EUROPE - CHOICE:MAP DOWNLOAD + ACTIVATION
£ 89.99 1 £ 89.99
Sub Total: £ 89.99
Total: £ 89.99 13MY Range Rover Sport Autobiography SDV6 - mine
Post #599660 Thu Jun 04 2020 6:22pm
Autobiography1969
OK,
So I emailed including my Vin Number
Hello I am looking to get the following update but not sure its right for my car
My VIN is SALLSAA**********
Can you tell me if this update on the sat nav is compatible?
Thank you
to;
rustymidgetman@sky.com
from
https://www.satnavupgrades.co.uk
Both do the same thing but slightly different prices.
Rusty has replied first,
Hi,
yes you have gen 2.1 here is what you need
https://www.satnavupgrades.co.uk/2019-LAND...p122222095
Rusty
As said its a little more expensive but if the other place does not answer this will be the one I use..
Just as a note I have no affiliation with either business,
so please check for yourself and choose whoever you wish to..
Post #599665 Thu Jun 04 2020 8:40pm
