![]() | Home > Technical > Special Programs Off then Engine System then Transmission |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Hi All
An update. Westboune Motors arrived; checked out the car and can find nothing wrong and no fault codes stored. Also the car is behaving itself still although I haven't been courageous enough to take it for a long run yet.
I used to get the Special Programmes unavailable when the battery was on its last legs. 2006 2.7 TDV6 HSE in Cairns Blue. |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
On our last Range Rover we lost all power and car went to limp mode, anything below 2500rpm it was sluggish above that it was fine, turned out it was the EGR valves which I blanked off and then it was fine, not sure if you can blank yours off tho.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
My previous sport used to do that occasionally when left, simply the battery got low and a good run always sorted it.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
It's an annual event.........usually brake light switch. |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
I go for the battery especially as its not been driven, give her a good run to charge it. |
Thanks for all the thoughts and suggestions guys. Lets pick up a few of those so that others reading this later may find it useful.
Yes jason-nike, I have used them before. In fact they installed my remote control FBH unit and did a good job. However I have since found Groombridges in Heathfield who are first class and also provide a free courtesy car whilst they play around with my car. Very convenient Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Good thought but the issue arose after a run to Hastings - a run of 26 miles and about 55 mins. Just trundling along on the outskirts of Hastings when "bong" warning noise and the suspension warning indicator lights up orange. I think no great worries as it'll probably go when I stop in Hastings and restart. Then it went to red. So I stopped to read up on it in the handbook. That says;
It goes on to say:
The lamp didn't flash - it was a solid red. But I turned off the engine, waited a couple of minutes and then restarted and it was all back to normal. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
The part where you switch off, re-start and everything is normal until the next hiccup is typical brake light switch.
If it's been flat a couple of times, properly flat, then it might have a weak cell. That will cause problems. I had a battery that lost a cell, my CTEK would run and say "it's charged", put a meter on it and it's 12.7V. Put a load on it and it dropped to <11V. If you change the brake pedal switch, be careful. There is a procedure involved - do a search as there are some good write ups on here. It's an easy enough job but there's something you mustn't do before it's fitted. Can't remember what but a search will show it. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Just another guilty admission - I actually drove straight past the Thatched Garage (Doh!!!). I was so anxious to nurse the car home that I totally blanked the thought of calling in there. And as you see if you watch the video below, the slight incline just after the Garage shows how bad limp mode really is. For those who haven't experienced it, you feel like the end of the world has come - well sort of. The "hill" is hardly one at all but you will see the way the speed just drops off. And there's nothing you can do about it. You're just willing the car to make it to the top! &feature=youtu.be Its not easy to see on the video but as I pass the Thatched Garage I am doing 38mph and by the end of the clip I am doing 33mph. And that's flat out! Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Don't release the plunger before installing the switch, when you turn the switch to locate it that will release it.
