![]() | Home > Technical > Special Programs Off then Engine System then Transmission |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Cheers Col Robin
That's a definite update I need to do then. Switch ordered ![]() 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Forgot to mention, do not press brake pedal when changing the switch as may well damage the new switch.
Sorry RRSTDV8, I missed your reply here in the flurry of others. But thanks for the heads up on the battery. Also note your thoughts about the brake light switch - I guess that's what Col was talking about Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Also Ford, Mazda & LR all use the same switch. For some reason, I find the Mazda lasts a longer on the average. |
I'v just taken the RRS up the road as an initial test - it behaved impeccably!!!
OK. Back from the indie. Guess what? Engine fault caused by .....
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Glad its all hopefully sorted |
