![]() | Home > Technical > Update....My RRS is a runner. |
Check injector wiring for chaffing.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
Cheers Andy, are the ecu’s prone to failure then? more so than injectors? I’ll check the simple things first, I’ve checked the plugs and wiring behind the battery and a quick look at the injector loomed on top of the engine.
No ecu aren’t a common problem
Info i gleaned from the Internet is injector firing info to the ecu is shared between two injectors so if one goes down it effects two, I’m at work on nights at the moment so lots of time to surf, info from the Disco 3 site points to injectors or wiring loom, I’ve got a resistance figure to check the injectors so at least I have a starting point.
Finally got some time off to investigate and it appears that water may have got into the engine ecu, I found a large round grommet in the bulkhead above the ecu behind the loom out.
Have you tried cleaning the contacts or are they rotted out? If rotted, do you think the ECU is toast or could a new connector work? If you open the casing and look at the connector, mouser Uk or similar probably carry a replacement circuit board connector. 2019 5.0 SC SVA (Current)
Yeah clean contacts and see how bad inside.
No it was very light corrosion that cleaned off, I haven’t had the lid off as it seems to involve bending the edge of the lid then it looks stuck on with black mastic and if I was going to get an exchange unit it wouldn’t look good.
I think the DC DC code means it’s fxxked |
Thanks Andy, I think you may be right that’s why the other banks now got a fault plus the other errors.
Been in touch with three local specialist, two are getting back to me if they can do it and one has given me a price for an exchange cloned unit of £425, bit much but on a 14 day return basis if it doesn’t work(£96 restock fee)
Sounds like my ECU is toast and they may not be able to pull codes from to clone, They’re going ring me tomorrow, if this is the case what are my options?. One that’s been mentioned is to replace the ECU set with a coded set from a donor vehicle? what parts do I need for this as there seems to be various available?
Update........My ecu is now at a new specialist and repair work is ongoing, damage was so extensive that repair work is being carried out in an attempt to retrieve Software and codes |
Sounds expensive |
