Home > General (L494) > Windscreen washer jet |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I'd say everything 'should' be checked, but it's apparent from reading here and online that things don't get checked. And the approved name doesn't seem to carry much weight either, I had to return my RRS a few weeks after I got it for EPB issue's when their technician picked up the rear disks were corroded and required replacement, after some grumbling I got a copy of the independent inspection which highlighted the corroded disks which then should have been replaced to conform to be approved - the Aberdeen dealer obviously hoped this would slip through to then be picked up at service and replaced as a consumable at my cost. 13MY Range Rover Sport Autobiography SDV6 - mine
Sun May 10 2020 12:23pm |
glenn9999 Member Since: 31 Aug 2019 Location: Essex Posts: 58 |
thank you for the advice once the lock down is over might get it checked just to be safe |
Sun May 10 2020 12:46pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 |
Number 44 on the approved used checklist - I’ve got the complete form if anyone wants it. 169 point check my
Sun May 10 2020 2:50pm |
I meant to add the washer jets do clip back on easily. I noticed my middle windscreen jetwash was hanging off after a service. They seem to work loose after repeated bonnet opening. Another quality JLR product 16MY Estoril Blue SVR.............
Sun May 10 2020 3:03pm |
it looks like someone in the past has tried to adjust the spray and the little black bit has snapped off so its just spraying down |
Sun May 10 2020 5:38pm |
