Home > General (L494) > Windscreen washer jet
glenn9999
Hello
just noticed on my approved RRS AB that the left washer jet is broken (picked up car the day of lock down so not used it until now ) should this be something that is covered under warranty and if not how much would a new one be
Also noticed that the A/C is not working should this have been checked ?
Post #598764 Sun May 10 2020 12:15pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I'd say everything 'should' be checked, but it's apparent from reading here and online that things don't get checked. And the approved name doesn't seem to carry much weight either, I had to return my RRS a few weeks after I got it for EPB issue's when their technician picked up the rear disks were corroded and required replacement, after some grumbling I got a copy of the independent inspection which highlighted the corroded disks which then should have been replaced to conform to be approved - the Aberdeen dealer obviously hoped this would slip through to then be picked up at service and replaced as a consumable at my cost. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #598765 Sun May 10 2020 12:23pm
glenn9999
thank you for the advice once the lock down is over might get it checked just to be safe
Post #598766 Sun May 10 2020 12:46pm
PEACHY
Number 44 on the approved used checklist - I’ve got the complete form if anyone wants it. 169 point check my Censored
Hope you can read it Thumbs Up 16MY Estoril Blue SVR.............
Post #598768 Sun May 10 2020 2:50pm
PEACHY
I meant to add the washer jets do clip back on easily. I noticed my middle windscreen jetwash was hanging off after a service. They seem to work loose after repeated bonnet opening. Another quality JLR product Rolling Eyes Laughing 16MY Estoril Blue SVR.............
Post #598769 Sun May 10 2020 3:03pm
glenn9999
it looks like someone in the past has tried to adjust the spray and the little black bit has snapped off so its just spraying down
Post #598776 Sun May 10 2020 5:38pm
