Home > General (L494) > SHIFT UNLOCK BUTTON BROKEN L494 |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 |
LR117072 Kit - Gear Shift Trigger Repair Set L494 Sport 8 Speed
Mon Sep 02 2019 12:16pm |
Harveyp500 Member Since: 08 Mar 2016 Location: Worcester Posts: 58 |
You can also source it from Brit-Car which is where i sourced mine from.
Fri May 01 2020 8:31am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9014 |
It appears that the Advanced Factor one is cheaper. And they're a site sponsor so you're supporting the forum by using them. 2012 SDV6 - it's missing a couple of cylinders
Fri May 01 2020 8:43am |
Much cheaper if you use the discount code INITTOGETHER to get 12% off your order. Paul Redding
Fri May 01 2020 10:02am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
OK, why does the kit come with a pair of socks? |
Fri May 01 2020 2:41pm |
Gingerg978 Member Since: 18 Jan 2018 Location: Berkshire Posts: 67 |
Socks are to keep the gear shifter warm in the winter.
Fri May 01 2020 3:21pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
If those"socks"fityour feet I'd hate to see your toes 2010 RRS, TDV8
Fri May 01 2020 4:43pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
I rarely wear shoes so mine look like a bit like that!! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Sat May 02 2020 8:43am |
Martyn Member Since: 28 Jun 2019 Location: Suffolk Posts: 64 |
Hi I've just changed mine, not because it was broken but because the P button looked like it was smudged and it was in my line of vision ......I've kept the old kit just in case it does ever jam
Thu May 07 2020 1:12pm |
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 |
Mine has just gone, car is stuck on carpark locked in park.
Tue Jun 16 2020 4:05pm |
Hello mate if you pull the bottom of the cup holders out there's a red ribbon, pull this and the car will go into neutral so you can get it moved until you get the switch |
Tue Jun 16 2020 4:29pm |
Mines going in to main dealer Thursday for a new one,LR tech came out Sunday as mine broke again after AA bodged it,he had a new switch but couldn’t fit it as he couldn’t get in touch with anyone at warranty care with it being Sunday but he fitted one that he had repaired which is probably stronger than original as they are only plastic.Im going to ask dealer for the old one back & keep it in glove box as a spare. Andy.
Tue Jun 16 2020 5:33pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Mine just went. Ordered from Advanced factors... BUT as a PSA - i can't think of any other part on the car, so easily replaceable and cheap that can totally immobilise it so easily. If you are planning a long road trip; suggest you get one and hope you never need to use it. 2022 P440e AB |
Mon Jun 14 2021 8:32am |
Paynee Member Since: 29 May 2021 Location: Sunderland Posts: 7 |
Did the discount code still work? Just tried to order one and it wouldn’t recognise? |
Fri Jul 02 2021 9:30am |
