Home > Maintenance & Modifications > Front Pad Question |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
Hi Guys,
Sat Apr 25 2020 3:21pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
16.6mm would be the thickness of a new pad, do not know your mileage but that would account for the wear not sure what lining thickness brembo advise changing them at, normally around when the wear gets close to the bottom of the two "grooves" in the lining I would imagine. L/R recommend minimum wear thickness of lining 3mm personally I would change them well before they got that low The wear indicator should illuminate when pads around 75% worn which would be advisable to change then at least. The backing plate on the pad is 5mm so in theory you could go around 8mm total thickness.
Sat Apr 25 2020 9:59pm |
Hi Col,
Sat Apr 25 2020 10:13pm |
Personally I would change them when they were worn down to 4/5mm minimum.
Sun Apr 26 2020 1:03am |
