![]() | Home > Technical > Another ‘suspension will raise when system has cooled’ p |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
The compressor has 2 temperature sensors. (they are the thin wires)
CM07DAY Member Since: 25 Oct 2019 Location: Brighton Posts: 8 ![]() ![]() ![]() |
I’ve not got an iid tool and they look pretty expensive |
Check the connections to the small wires in the compressor then |
Is it this
update:
Is the reservoir tank rusty? If it has a hole then pump will over run.
the reservoir tank did cross my mind actually, will have a look in the morning to see its condition, however living on the southcoast its not gonna be pretty under there |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Spraying soapy water over the tank might help show up any leaks as it'll bubble.... |
Update:
Height sensor? Without reading the codes with an IID or similar then a guessing game.
Are you sure the relay is ok ?
Yeah planning to get it read as soon as a garage is open again!
So had it plugged in and after the initial codes were reset, no codes came up relevant to the suspension
