Home > Technical > Diesel Leak under engine |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 203 |
Anybody???? 2015 L494 SDV6 3.0 HSE Dynamic
Tue Apr 14 2020 6:23pm |
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 |
I had an issue with non genuine fuel filter not sealing properly. Fitted a genuine and problem solved. Drain underneath can also work loose or snap if over tightened. |
Tue Apr 14 2020 9:57pm |
Ok, thanks for replying.....will check it out when i can 2015 L494 SDV6 3.0 HSE Dynamic
Tue Apr 14 2020 10:26pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
I would give it all a good clean and then try to see where it's coming from. Kev
Wed Apr 15 2020 1:52pm |
Yeah thanks Kev, will need to get underneath and remove the covers and the heat shield to reveal the fuel filter, then start her up and see where it's coming from 2015 L494 SDV6 3.0 HSE Dynamic
Wed Apr 15 2020 2:19pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
remove the plastic under tray below the gearbox (where the front doors are) |
Wed Apr 15 2020 3:52pm |
Yeah thanks Andy, seen a video on youtube 2015 L494 SDV6 3.0 HSE Dynamic
Wed Apr 15 2020 4:05pm |
Update:
Mon Apr 20 2020 3:05pm |
