Home > Technical > Diesel Leak under engine
skid1963
Hi Guys and Gals
As per title
Was doing a bit of work during this lockdown on my RRS, got low power mode come up on dash so thought i'd start her up for a bit to recharge battery.
I do know these motors don't like sitting there idling for any length of time so i only had it ticking over for about 5 minutes.
Stepped out of car and noticed a small river of fluid spreading on the concrete sloping drive i have from under the car, dipped fingertip in and could smell it was diesel.
I had cambelt/oil pump/water pump/gearbox flush/all filters changed about 2 months ago.
My question is could the fuel filter not have been seated correctly if that is a "thing", seems to be a lot of fuel for it to be anything else, the whole underside of the rear of the engine and the gearbox looked quite wet so it clearly has been occurring whilst driving also.
Any ideas appreciated
Thanks 2015 L494 SDV6 3.0 HSE Dynamic
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #597663 Sun Apr 12 2020 10:59am
skid1963
Anybody???? 2015 L494 SDV6 3.0 HSE Dynamic
Post #597746 Tue Apr 14 2020 6:23pm
rob cupples
I had an issue with non genuine fuel filter not sealing properly. Fitted a genuine and problem solved. Drain underneath can also work loose or snap if over tightened.
Post #597755 Tue Apr 14 2020 9:57pm
skid1963
Ok, thanks for replying.....will check it out when i can 2015 L494 SDV6 3.0 HSE Dynamic
Post #597757 Tue Apr 14 2020 10:26pm
knwatkins
I would give it all a good clean and then try to see where it's coming from. Kev
Post #597768 Wed Apr 15 2020 1:52pm
skid1963
Yeah thanks Kev, will need to get underneath and remove the covers and the heat shield to reveal the fuel filter, then start her up and see where it's coming from 2015 L494 SDV6 3.0 HSE Dynamic
Post #597769 Wed Apr 15 2020 2:19pm
remove the plastic under tray below the gearbox (where the front doors are)
Post #597779 Wed Apr 15 2020 3:52pm
skid1963
Yeah thanks Andy, seen a video on youtube 2015 L494 SDV6 3.0 HSE Dynamic
Post #597780 Wed Apr 15 2020 4:05pm
skid1963
Update:
Turns out it was the tiny o-ring on the water-in-fuel sensor attached to the top of the fuel filter, my indie just popped the plastic plug that comes with the filter in it's place, he said it happens a lot and many RRS's are running around the same, will see about getting the o-ring or a new sensor when it comes to my service........in short, leak stopped Very Happy 2015 L494 SDV6 3.0 HSE Dynamic
Post #597930 Mon Apr 20 2020 3:05pm
