Home > Technical > 2006 RRSS, “Transmission Fault, Traction Reduced”
Indirocz28
United States
Hello all, new rover owner here.
I just picked up this decently clean 2006, and I wanted to check the differential fluids before a trip this weekend. First let me start off by saying I am mechanically inclined, but that doesn’t mean I’m perfect, or familiar with something new.
On the rear diff, to the driver side of the pinion there is a long “nut” that is spring loaded.
I mistook this for the differential fill plug.
And after filming I got a “transmission fault, traction reduced” error.
Could it be the fact that I most likely over filled it, or is it because I removed that spring loaded pin/nut assembly?
Thank you.
Post #597638 Sat Apr 11 2020 4:02pm
Is it the active differential (the one that can lock)? That has motor on top. No motor then not active. The active diff uses a different oil to the open diff.
The nut you removed. Was it very big and long? If so, that sounds like a mass damper. There is one on the front face of the active diff.
Or did the nut have a wire running to it and was situated above/in a U shaped guard? That's the oil temperature sensor. If there's a problem with that then the ECU might decide it's overheating and so give the warning because it thinks it can't lock the diff. 2012 SDV6 - it's missing a couple of cylinders
Post #597641 Sat Apr 11 2020 11:20pm
Any chance the part circled is the part you are referring to as having removed?
Post #597642 Sat Apr 11 2020 11:45pm
Indirocz28
United States
Col, yes that is the part I removed, and filled the diff up to that point.
Post #597643 Sun Apr 12 2020 2:56am
Indirocz28
United States
It was the “mass damper”.
Post #597644 Sun Apr 12 2020 2:57am
Indirocz28
United States
Col, yes the circles “damper” is what I mistakenly removed, filled to that hole level and re-installed.
Post #597645 Sun Apr 12 2020 3:38am
erickwan
Malaysia
From the official Workshop Manual..........
[/img]
Post #597919 Mon Apr 20 2020 3:34am
Indirocz28
United States
I fixed the issue.
I did drain out the excess fluid, but the fault was still present.
Then what ended up happening is I decided to remove the hexagonal plug/pin again and have a look inside.
Inside that hole there is a “collar” that spins around. If you pay close attention you will spin it enough and see that it ramps up going either way. In the middle of these little ramps with square faces is a machined notch. I simply lined that back up with the hole and put the plunger pin in it, then tightened it back up and the fault immediately cleared itself on key up.
Post #597927 Mon Apr 20 2020 12:44pm
