Home > Technical > 2006 RRSS, “Transmission Fault, Traction Reduced” |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Is it the active differential (the one that can lock)? That has motor on top. No motor then not active. The active diff uses a different oil to the open diff.
Sat Apr 11 2020 11:20pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Any chance the part circled is the part you are referring to as having removed?
Sat Apr 11 2020 11:45pm |
Indirocz28 Member Since: 11 Apr 2020 Location: TX Posts: 7 |
Col, yes that is the part I removed, and filled the diff up to that point. |
Sun Apr 12 2020 2:56am |
It was the “mass damper”. |
Sun Apr 12 2020 2:57am |
Col, yes the circles “damper” is what I mistakenly removed, filled to that hole level and re-installed. |
Sun Apr 12 2020 3:38am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
From the official Workshop Manual..........
Mon Apr 20 2020 3:34am |
I fixed the issue.
Mon Apr 20 2020 12:44pm |
