![]() | Home > Wheels & Tyres > Why not to fit 23” alloys. |
For the second time,,33 fronts & 37-38 rears |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
Haha thank you Andy, duno why that posted twice. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
I’m currently running 34 on the front and 38 on the rear. I’ve tried quite a few different pressures and this so far has been the best for my car so far. I did try as high as 40 on the rear but I found it really harsh and the pressure rose dramatically in line with the temp. 2019 5.0 SC SVA (Current)
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 244 ![]() ![]() |
When my RRS was delivered the PSI was at 50 on all corners and it was set to “heavy load” or whatever it’s called. I dropped the pressures and changed the setting to “light load” it made a massive improvement in rose quality. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
