Home > General > Car laid up
Page 1 of 3 123>
stevoc
Scotland
Car laid up
Hi guys.
I’m wondering,due to the current situation we all find ourselves in, is how should the car be “laid up”during the crisis.
I’m more talking of the suspension setting ie what height should we leave it at. I’ve heard a few differing opinions of the best course of action. Also the EPB. The last thing I want is that failing again.
Thank you.
Post #597304 Fri Apr 03 2020 7:41pm
I wouldn’t worry about those things.
Just keep the battery charged
Are you isolated for 12 weeks?
Post #597306 Fri Apr 03 2020 7:45pm
DrRob
Gearbox in P. EPB off.
Ctek charger into tow electrics or to battery or a solar Optimate
Lower suspension if you want.
Don’t start it once a week. Not worth it Visitor from fullfatrr.com
Post #597312 Fri Apr 03 2020 9:15pm
Disco_Mikey
EPB off
Trickle charger hooked up
Leave it. Don't be tempted to start it and run it once a week. That will do more harm than good
Post #597313 Fri Apr 03 2020 9:16pm
Yeah, used to work abroad a lot so car parked up 3 months at a time, left in normal ride, height, EBC off and Ctek charger connected, never had any issues.
Post #597315 Fri Apr 03 2020 9:56pm
Tim in Scotland
How do you get round the EPB automatically engaging as used to happen with both my 2007 L320 TDV8 and my 2015.5 SDv6? I never had a problem with them disengaging after 3-4 months , yes they would be sticky but they never jammed on, same with the L322 FF’s and both Evoques I’ve owned, the EPB was never an issue and the cars all lived out on the drive and often for the whole winter. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #597320 Sat Apr 04 2020 7:21am
You deactivate auto engagement for the EPB in the CCF files.
Post #597323 Sat Apr 04 2020 7:43am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Initially my auto EPB was off so I turned it on in the CCF as I'd never rely on the park pawl only, especially with the high winds up so probably rocking the RRS back and fore. Now if I manually move to Park the EPB does not automatically come on, only if shutting down the engine in a gear including R.
This may have changed with newer ones as there is no way of preventing my wife's Evoque EPB applying, it happens regardless of what the gear selector is on but I haven't been into the CCF on it. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #597325 Sat Apr 04 2020 8:54am
Disco_Mikey
Unsure of the CCF settings, but you can put the newer cars into EPB maintenance mode to prevent the EPB applying when ign off Thumbs Up
Post #597326 Sat Apr 04 2020 8:57am
insiorc
Re: Car laid up
stevoc wrote:
Hi guys.
Thank you.
The suspension being air won't be affected, I was working a month on/off so the EPB could be left on the whole month with no issue's, I'm more concerned about brake disk corrosion as per this thread - https://www.rrsport.co.uk/forum/topic56006.html 13MY Range Rover Sport Autobiography SDV6 - mine
Post #597327 Sat Apr 04 2020 8:58am
stevoc
Scotland
Disco_Mikey wrote:
EPB off
Hey disco mikey. My car is parked too far away from my house for a trickle charger.
Is there any alternative to that? Would disconnecting the battery help/ or cause any issues?
Post #597328 Sat Apr 04 2020 9:04am
I thought holding down the park brake while turning ignition off would stop it applying
Well something like that
Post #597329 Sat Apr 04 2020 9:04am
stevoc
Scotland
Hi Andy. Not quite isolating but I’m just not driving the car at all. I know how temperamental these bad boys are so just wanting to be prudent till we can all get back enjoying them again.
Post #597330 Sat Apr 04 2020 9:08am
Pufftmw
If its left outside, then just get a Solar Battery Charger - loads on eBay.
Have to say I leave my car for weeks at a time and don't do any of the above and its still fine!
Post #597331 Sat Apr 04 2020 9:23am
knwatkins
Inflate the tyres to prevent flatspotting. I've SORN my RRS and inflated the tyres to the maximum rating (50 psi) whilst it is stood idle. I've also connected my Ctek charger to keep the battery topped up. Kev
Post #597332 Sat Apr 04 2020 9:31am
Page 1 of 3 123>
