![]() | Home > General > Auto high beam |
Matt preece Member Since: 15 Feb 2020 Location: Sedbergh Cumbria Posts: 16 ![]() ![]() ![]() |
Hi my 2013 rrs auto high beam feature does not seem to work any ideas cheers |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I agree with the above, I have it on but you have to anticipate whether it is likely to go to dip quick enough or not, it depends whether the approaching car is on a corner, in a dip or behind a bump etc. It is very quick at going back to full beam which is why I still use it, and as soon as you manually operate it then it stays manual until the stalk is pushed fully forward again. For the OP's question, I can't remember but is the on/off option in the on screen menu accessed via the stalk? 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Yes, auto high beam is buried in the menu via the stalk.
Has anyone got experience of this function in any other vehicles?
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
I think it’s really good on both of mine. RRS MY17 SDV6 AB
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
I have an MY12, registered 2013, one of the last RRS1s. Don’t have HBA So not used to it, but your car is now 7 or 8 years old, the technology is stone aged.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I found it to slow to dip and to easily activated by reflective road signs so switched it off. Setting is in the vehicle setup menu via r//h steering wheel menu button.
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 ![]() ![]() |
I find it works well but sometimes it confuses me, if I am following another car the blue high beam light stays on but the headlamps have adapted to the situation in that they don’t light up the car in front but still light up the nearside verge.
You have Matrix LED but the OP has bi-xenon in an L320.
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
My Tesla Model S is spot on with auto high beam, I couldn't react that fast! 2018 Telsa MS
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
first thing i disabled on mine when i picked it up in 2010, it caused no end of grief due to
I have used the same HBA in the USA without issue and was very impressed. The same system in the UK isn’t anywhere near as good. I can only put it down to straighter and wider roads with less cluttered verges in the US. 2019 5.0 SC SVA (Current)
