Home > General > Front end noise when cornering
Heliflyer61
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Good afternoon my 2010 RRS has started making a slight wurring sound when cornering not major noise yet but don’t like to hear anything that shouldn’t be there anyway my first thoughts was maybe the front hub bearings but jacked it up and no movement up or down on the wheels has anyone any other ideas it will be going in to specialist I’m just curious what it could be ideas welcome cheers Ian
Post #596482 Sat Mar 14 2020 3:08pm
LordWeresey
Hi Heliflyer
Sounds like it could possibly be the bushes needing replacement?
Post #596569 Mon Mar 16 2020 11:02am
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Hello Heliflyer, not going to comment on your problem but nice to see someone local on here. Cheers Andy.
Post #596570 Mon Mar 16 2020 11:09am
Heliflyer61
LordWeresey wrote:
Hi Heliflyer
cheers i have recently had the arb bushes replaced what others are there cheers Ian
Post #596572 Mon Mar 16 2020 11:32am
Heliflyer61
Post #596573 Mon Mar 16 2020 11:33am
LordWeresey
Heliflyer61 wrote:
LordWeresey wrote:
Hi Heliflyer
Ooh I'm not so sure then - I had a similar issue and took to my garage who replaced the bushes and fixed it - I'm stumped now Big Cry
Post #596575 Mon Mar 16 2020 11:52am
Eaters
My guess is that I'd look again at the wheel bearings. When I had issues with my RRS, I took it to my local indie who said, lets go for a quick test drive. Up the road we went, and he gently turned the steering from side to side. Within minutes he said "its you offside front wheel bearing. Listen". And then I could hear it. Wheel bearing replaced and all was better.
The other thing to look for is something fouling - so look for any shiny surfaces behind the wheels.
One other thought is whether the power steering has an issue??? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #596669 Wed Mar 18 2020 9:04am
knwatkins
I'm with Robin on this and would look at replacing your wheel bearing.
A whirring noise would only be caused by a rotational movement. Given this is occurring when cornering when the centre of gravity of the vehicle is shifted further towards the said bearing and greater force is therefore placed upon it, it makes sense.
Worn wheel bearings do not always exhibit play.
Concerning replacements, it is best to buy the complete hub assembly. Do not buy a cheap one for these vehicles because it will fail in no time. Either go for: Genuine Land Rover (££££), Timken (OEM, same part as genuine @ approx £125) or Optimal from AF (4 year warranty, £72)
I had play in my front nearside bearing and I changed it on the weekend for an Optimal. It was a simple enough job to do on the driveway. Kev
Post #596685 Wed Mar 18 2020 3:41pm
DrRob
Advanced Factors (AF in last post) is a site sponsor in Southampton is the place to go. Talk to Paul Redding there Thumbs Up
https://www.advancedfactors.co.uk/range-ro...13-3-c.asp Visitor from fullfatrr.com
Post #596687 Wed Mar 18 2020 4:40pm
