![]() | Home > Faults & Fixes > Suspension light on after 20 econds |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
Not posted on here for ages as its been behaving itself until now!!
So the Fault code is U0132- Lost communication with Ride Level Module.
So this fault went away but has now come back, Anyone got any ideas?
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 ![]() ![]() ![]() |
I had a fault on my l320 with suspension light coming on ,it was the lateral accelerometer, had it replaced faults gone now |
Well I think I might have fixed the Suspension fault!!
Works from mobile device....
Good find, if you’ve got some Vaseline, smear it around the mating surfaces of the plugs to help keep moisture out. You can also put some on the back of the shell where the wires pass through. 2019 5.0 SC SVA (Current)
