Home > Faults & Fixes > Suspension light on after 20 econds |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 |
Not posted on here for ages as its been behaving itself until now!!
Fri Jun 21 2019 9:13pm |
So the Fault code is U0132- Lost communication with Ride Level Module.
Sat Jun 22 2019 10:32am |
So this fault went away but has now come back, Anyone got any ideas?
Tue Mar 03 2020 8:21pm |
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 |
I had a fault on my l320 with suspension light coming on ,it was the lateral accelerometer, had it replaced faults gone now |
Tue Mar 03 2020 8:44pm |
Well I think I might have fixed the Suspension fault!!
Sun Mar 08 2020 12:55pm |
Sun Mar 08 2020 1:00pm |
Works from mobile device....
Sun Mar 08 2020 5:26pm |
Good find, if you’ve got some Vaseline, smear it around the mating surfaces of the plugs to help keep moisture out. You can also put some on the back of the shell where the wires pass through. 2019 5.0 SC SVA (Current)
Sun Mar 08 2020 6:17pm |
