Home > In Car Electronics > 2007 RRS HSE 6CD Head Unit Stuck on Phone Mode
d4funky1
Since the last month my head unit is now constantly stuck on 'phone mode'
All buttons are unresponsive and after searching here is what I have tried so far:
Disconnecting the negative battery terminal for 5 minutes and reconnecting
Removing the fuses and replacing
The strange thing is that when I remove either the 30a fuse or the 10a fuse from the glove box the unit kicks out of phone mode and is fully functioning WITHOUT SOUND???
Once I replace the fuses the unit goes back to phone mode. If I connect my phone I can use it as normal.
Can anyone please offer any advice? The garage claims that the unit will need replacing but there must be some sort of fix?
Thanks in advance
D4
Post #595748 Fri Feb 28 2020 5:34pm
What number fuses are u removing
Post #595751 Fri Feb 28 2020 6:33pm
d4funky1
Thanks for your reply.
As per the attached image I have removed and replaced the following fuse numbers from the glove box fuse box:
42, 52, 53, 57 & 58
https://ibb.co/sCB1yFz
Post #595805 Sat Feb 29 2020 4:08pm
d4funky1
Anyone got ideas on this?
Thanks again
D4
Post #595878 Sun Mar 01 2020 9:25pm
