![]() | Home > General (L494) > Disabling Keyless Entry |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
I have the same model & year & that worked first time for me - trouble is I keep forgetting & walk up & pull the handle then realise I need to press the |
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 ![]() ![]() |
I think you have done half a job, to deactivate , headlamp x3 plus unlock. To rest, headlamp x3 plus lock button |
teldec Member Since: 29 Dec 2019 Location: essex Posts: 79 ![]() ![]() |
try this, Unlock car..sit in drivers seat.
glenn9999 Member Since: 31 Aug 2019 Location: Essex Posts: 58 ![]() ![]() |
managed to do it but what was confusing me was that in the videos the lights did not flash but mine did and it disabled the keyless entry
chrisjsw Member Since: 10 Jul 2018 Location: Buckinghamshire Posts: 71 ![]() ![]() |
The drivers door must be shut and you must be inside the vehicle - if memory serves. 2015 Range Rover Sport L494 HSE Dynamic
crasher73 Member Since: 31 Jan 2020 Location: Peterborough Posts: 23 ![]() ![]() |
It didn't work to start with on my MY16 because I sat in the car with the drivers door shut. I found the process was to have the drivers door open whilst sat in it. Press headlight button 3 times and then unlock button and this worked a treat |
managed to get it working on mine now so happy |
