Home > General (L494) > Disabling Keyless Entry
glenn9999
Hello All
just collected a RRS MY16 AB and love it first RR i have had but i would like to disable the keyless entry
i have found a video on youtube but the steps do not seem to work
it says
press lights button on key 3 times
then press unlock button
when i do this the lights just flash 3 times and then the doors try to unlock
any ideas
Post #595742 Fri Feb 28 2020 3:57pm
PEACHY
I have the same model & year & that worked first time for me - trouble is I keep forgetting & walk up & pull the handle then realise I need to press the Censored button. Rolling with laughter
Did you lock it after ? Or just pull the handle ? Was the drivers door open or closed ?
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #595750 Fri Feb 28 2020 6:15pm
Cornishman
Deactivating keyless entry
I think you have done half a job, to deactivate , headlamp x3 plus unlock. To rest, headlamp x3 plus lock button
Post #595753 Fri Feb 28 2020 7:18pm
teldec
try this, Unlock car..sit in drivers seat.
Press headlight butyon 3 times then unlock button.
You wont notice anything or see any indication..you will know its worked when you try to lock the car using the keyless button / dimple on car door handle or try opening door without using key fob button.
Post #595755 Fri Feb 28 2020 7:23pm
glenn9999
managed to do it but what was confusing me was that in the videos the lights did not flash but mine did and it disabled the keyless entry
thanks
Post #595765 Fri Feb 28 2020 11:03pm
chrisjsw
The drivers door must be shut and you must be inside the vehicle - if memory serves. 2015 Range Rover Sport L494 HSE Dynamic
Works at an Indy in Herts
Post #595848 Sun Mar 01 2020 11:19am
crasher73
It didn't work to start with on my MY16 because I sat in the car with the drivers door shut. I found the process was to have the drivers door open whilst sat in it. Press headlight button 3 times and then unlock button and this worked a treat Thumbs Up
Post #595945 Tue Mar 03 2020 8:41am
glenn9999
managed to get it working on mine now so happy
Post #595951 Tue Mar 03 2020 11:51am
