Home > Faults & Fixes > Xenon light problem |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Will ask the obvious but does the working bulb work on both O/S and N/S? to determine if the problem is the bulb or the car. D1s would appear to be the wrong bulb anyway.
Tue Feb 25 2020 12:14am |
Skysafe Member Since: 24 Feb 2020 Location: Gothenburg Posts: 2 |
Do you mean that I can swap The whole headlight and connect The cable to see if The one that works fine also works on the other side? |
Tue Feb 25 2020 11:17am |
No, I meant swap just the bulb from the passengers side as I assume that is the one still working, and fit it to the drivers side to see if it works ok to narrow it down to either bulb or wiring. In either case the new bulbs you have appear to be the wrong one's
Tue Feb 25 2020 8:40pm |
Also check your fuzes. 2019 5.0 SC SVA (Current)
Fri Feb 28 2020 2:32am |
For some strange reason I didn't think the headlights were protected by Fuses, thought they were protected by Field Effect Transistors (FET's.). Not sure if they can be replaced individualy or if it's a whole new CJB if it fails completely.
Fri Feb 28 2020 3:39am |
