![]() | Home > Technical > REDUCED ENGINE PERFORMANCE?????? |
Shauny0809 Member Since: 01 Jun 2018 Location: Wigan Posts: 33 ![]() ![]() ![]() |
Ok will try that does it aft be 1 of the above or would 1 those Hawkeye Land Rover code reader work |
Would 1 of them landrover Hawkeye work or does need to be as u stated above |
A Hawkeye should read it |
All I got of the code reader was missfire 2468 with no really codes I’ve replaced the fuel pump filter today and still hasn’t fixed it still going in reduced proformance mode and gets the odd yellow engine flash now and again dunno wat else could be h |
Ok when you say misfire 2468 i assume you mean the misfire is on cylinder 2 4 6 and 8 as you have not really explained the code you have as that just says you have a misfire on those cylinders and it is not a code |
Stoutster Member Since: 02 May 2019 Location: Hartlepool Posts: 5 ![]() ![]() |
Aux cooling pump , replace had the same issue. |
