Home > Technical > REDUCED ENGINE PERFORMANCE??????
Shauny0809
Ok will try that does it aft be 1 of the above or would 1 those Hawkeye Land Rover code reader work
Post #558103 Mon Jun 04 2018 10:09am
Shauny0809
Would 1 of them landrover Hawkeye work or does need to be as u stated above
Post #558104 Mon Jun 04 2018 10:11am
geoffsnook
A Hawkeye should read it Thumbs Up
Post #558108 Mon Jun 04 2018 11:19am
Shauny0809
Sorted for thurs to be read I had it read other day by landrover independent and they said it had low fuel pressure was a code and the imertent miss fire or something
Post #558171 Tue Jun 05 2018 10:11am
Shauny0809
All I got of the code reader was missfire 2468 with no really codes I’ve replaced the fuel pump filter today and still hasn’t fixed it still going in reduced proformance mode and gets the odd yellow engine flash now and again dunno wat else could be h
Post #558615 Sun Jun 10 2018 2:28pm
geoffsnook
Ok when you say misfire 2468 i assume you mean the misfire is on cylinder 2 4 6 and 8 as you have not really explained the code you have as that just says you have a misfire on those cylinders and it is not a code Thumbs Up
Post #558627 Sun Jun 10 2018 5:54pm
Stoutster
Aux cooling pump , replace had the same issue.
Post #595505 Mon Feb 24 2020 12:47pm
