![]() | Home > In Car Electronics > PIN CODE for GPS diagnostic? |
Try 7 5 3 ok 2019 5.0 SC SVA (Current)
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 ![]() ![]() |
will this work on a 2012 ? 2016 Range Rover Sport SDV6 autobiography (MY17)
Get onto the home screen
many thanks - will try that 2016 Range Rover Sport SDV6 autobiography (MY17)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Don't need a pin number for a 2012.
Humm there is loads to see in denso 2010 models.
Yes, there is a lot of info. something like 12 pages at least but you can't do anything much with it even if you understand it, it is just basic information of no use to the owner, and don't think you can actualy change anything much. What they will do is touch a button the screen will go blank and think |
I found it useful to check wheel speed and calculated gps speed. |
Will have to have a look out of curiosity, as don't ever recall seeing GPS mentioned on mine.
jmadro Member Since: 21 Nov 2019 Location: sevilla Posts: 3 ![]() ![]() ![]() |
