Home > In Car Electronics > PIN CODE for GPS diagnostic?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. How do I find the Pin Code for the GPS diagnostic screen to appear? I know after holding my figure on the screen for a period, the screen asks for the pin code. Andrew Kennedy
Post #571916 Sat Dec 29 2018 3:11pm
Brit Plumber
Try 7 5 3 ok 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #571925 Sat Dec 29 2018 4:29pm
John1311
will this work on a 2012 ? 2016 Range Rover Sport SDV6 autobiography (MY17)
2017 Range Rover Velar First Edition SDV6
2015 Range Rover Sport Autobiography 4.4
2012 Range Rover Sport SDV6 HSE Luxury Black
Post #595253 Thu Feb 20 2020 6:19pm
Get onto the home screen
Early models:
Hold your finger at the top middle of the screen for at least 3 seconds
Press the hard nav key for at least 3 seconds.
number entry screen should appear. 753
Late models:
Hold your finger at the top left of the screen for at least 3 seconds
Post #595255 Thu Feb 20 2020 6:41pm
John1311
many thanks - will try that 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #595258 Thu Feb 20 2020 6:50pm
Don't need a pin number for a 2012.
Just touch and hold the Valet Button on Home Screen for at least 20 Seconds, not that there is much to see.
Post #595265 Thu Feb 20 2020 8:55pm
Humm there is loads to see in denso 2010 models.
Even a second page
Post #595268 Thu Feb 20 2020 9:45pm
Yes, there is a lot of info. something like 12 pages at least but you can't do anything much with it even if you understand it, it is just basic information of no use to the owner, and don't think you can actualy change anything much. What they will do is touch a button the screen will go blank and think Censored what have I done now and panic as what to do next.
Next, don't panic switch off and lock the car, walk away for half hour and let car go to sleep and when you return all will be good. Rolling with laughter
Post #595272 Thu Feb 20 2020 9:52pm
I found it useful to check wheel speed and calculated gps speed.
Post #595277 Thu Feb 20 2020 10:54pm
Will have to have a look out of curiosity, as don't ever recall seeing GPS mentioned on mine.
Absolutely nothing mentioned that I can see about the GPS/Wheel Speed in any of the sections listed in the menu on my MY13 facelift car, just a lot of stuff to say the version/status of things etc. and whether activated or not some you can test/check but you can't change any of it in there anyway, although maybe a dealer can with T4.
Post #595282 Thu Feb 20 2020 11:43pm
jmadro
Spain 2007 Range Rover Sport TDV6 HSE Buckingham Blue
753
Post #597472 Tue Apr 07 2020 11:37am
