Home > General > After service test drive
drexal
United Kingdom 2012 Range Rover Sport Supercharged HSE Santorini Black
Hi all,
Random one, but my RRS 2012 V8 SC just came back from it service, and my tracker tells me that the mechanic it took it for a 1km drive before the service with a max speed of 40mph & average speed of 6mph which sounds completely normal.
When i drive it locally i'm lucky to reach a max speed of 20mph with an average of 5mph speed
But then it was taken for another test drive i'm presuming after the service which the mechanic took it for a 3.4mile drive and reached speeds of 61mph and average speed of 11mph all these roads they traveled on are london roads with speed limits of 40mph max.
This journey should have taken 16mins usually but took them 13mins.
Does this sound normal? Or do you think thats a big excessive and they decided to have a rag around in my car.
Any thoughts would be really appreciated. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594842 Fri Feb 14 2020 12:30pm
Brit Plumber
I think it could be hard to say either way, they could say a test drive will put it through its paces and check everything under load but do they really need to test drive it. I don’t think my car gets a test drive as part of its service.
Let’s hope you don’t don’t get an SP60 through the post. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #594886 Sat Feb 15 2020 9:03am
A nice careful drive before the service (to see if anything needs attention)
A good drive after the service to ensure they haven't made anything worse
You wouldn't want to have to take it back complaining, would you
Post #594891 Sat Feb 15 2020 10:22am
Dave-t
Absolutely needs a short test drive. On my D4 they (main dealer) did a 4 wheel alignment, obviously didn't do a test drive, the steering wheel was well off and pulling everywhere. I then had to rebook it at even more inconvenience to me. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #594892 Sat Feb 15 2020 10:31am
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Had some work done on mine recently & it was also taken to have the alignment done , on my return they informed me that the vehicle now drove superbly which it does, he also let me have a drive of his TDV8 which had EGR deleted & had been remapped to show me how much improvement can be had. I have no issues with them driving my vehicle.
Post #594896 Sat Feb 15 2020 10:49am
drexal
Thanks for replying guys, they had new RRS's in there to so doubt my old 2012 is that thrilling to drive compared to the brand new ones, so i'm prob just being super precious thanks for letting me know paranoia got the best of me! 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594914 Sat Feb 15 2020 4:31pm
Disco_Mikey
Test drive AFTER the service. Very rarely do I test drive before
Been on the wrong end of leaking brake pipes once too often, so the car is brought in, checked over and serviced first Thumbs Up
Post #594920 Sat Feb 15 2020 5:22pm
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
And just to add Mike, that the journey back up to the Highlands after the service and gearbox flush, was superb. Very smooth gear changes now. Well worth the 380 mile round trip. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #595057 Mon Feb 17 2020 10:01am
J.Prezes
Poland 2011 Range Rover Sport Supercharged Autobiography Santorini Black
It doesn't seen excessive at all and I wouldn't worry about the top speed knowing how effortless 5.0 sc accelerate to 61 mph but I know that they could have stepped on it thru first and second gear. As I said I just wouldn't worry. I think the best indicator would have been the fuel level if You were to worry about them hooning around in Your pride and joy
Post #595079 Mon Feb 17 2020 3:08pm
drexal
Thanks for all replying on this Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #595719 Fri Feb 28 2020 11:03am
