Home > General > DYNAMIC ANTI-ROLL BAR PIPE LEAK. |
You can’t replace with a LR part as it’s part of the greater assembly however if you have an agricultural suppliers nearby, they may be able to provide a solution. However it may only be an off vehicle repair in which case you just want to replace the lot as I bet the pipes will be badly corroded around the clamp to chassis mount. 2019 5.0 SC SVA (Current)
Mon Feb 17 2020 9:36am |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 |
Believe it or not, it is actually cheaper to buy the complete pipe kit then an individual pipe.
Mon Feb 17 2020 1:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
We certainly dont lift the body off to do either front or rear pipes... |
Mon Feb 17 2020 2:32pm |
Absolutely right DM. Not a body OFF, but body UP job.
Please excuse the typo Joe |
Mon Feb 17 2020 3:06pm |
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 |
Ok thanks for that, it’s going in to my local Indy to have the front pipes replaced & fingers crossed they can seal them to the block so I don’t need a new one of them 😑 |
Sun Feb 23 2020 10:01am |
