Home > General > DYNAMIC ANTI-ROLL BAR PIPE LEAK.
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi all, I have a 2010 RRS which has a dynamic anti-roll bar hydraulic leak from a pipe/hose on the driver side front, can it be replaced or repaired, it is leaking from this pipe with the arrow pointing to it, the hole/split is exactly where the arrow is. Sad
Post #595007 Sun Feb 16 2020 4:19pm
Brit Plumber
You can’t replace with a LR part as it’s part of the greater assembly however if you have an agricultural suppliers nearby, they may be able to provide a solution. However it may only be an off vehicle repair in which case you just want to replace the lot as I bet the pipes will be badly corroded around the clamp to chassis mount. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #595053 Mon Feb 17 2020 9:36am
OvalAutos
Believe it or not, it is actually cheaper to buy the complete pipe kit then an individual pipe.
Thats the good news. The bad news is that it requires the body off to change any of the pipes that run back to the control block (under driver's seat) Big Cry Joe
Post #595068 Mon Feb 17 2020 1:34pm
Disco_Mikey
We certainly dont lift the body off to do either front or rear pipes...
Post #595075 Mon Feb 17 2020 2:32pm
OvalAutos
Absolutely right DM. Not a body OFF, but body UP job. Bow down
Quote:
The six pipes connecting the pump, reservoir and actuators are one-piece components. If the pipes require replacement during service, the pipes are supplied individually and are removed and replaced in one piece. The front and rear pipes require the body to be lifted slightly to allow access for removal and replacement
Please excuse the typo Big Cry Joe
Post #595078 Mon Feb 17 2020 3:06pm
Baz0195
Ok thanks for that, it’s going in to my local Indy to have the front pipes replaced & fingers crossed they can seal them to the block so I don’t need a new one of them 😑
Post #595434 Sun Feb 23 2020 10:01am
