![]() | Home > General (L494) > Front pad change with Brembo |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I’m also just starting the adventure so please carry on. |
ballast Member Since: 20 Jan 2019 Location: MK Posts: 7 ![]() ![]() |
Fronts easy....
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
Just done mine. For balance an absolute pig of a job. Full LR service history. They had put the pins and pads in dry 🤡. No way were they coming out with any punch. A thorough bending of pins then restraighten etc eventually freed them enough to get out. One pad was still completely seized in caliper. Eventually pried out. Cheers Land Rover!!
You shouldn't use copper grease on aluminium calipers |
Mike,while we are on the subject of brakes,I’m going to change both my fronts & rears & im thinking EBC discs & EBC low dust pads,which disc do you recommend as their is a few on the site,Drilled,Drilled & grooved as I’m wanting to match front with rears.Price wise isn’t a issue as I’m wanting to change them before MoT in March as I’m sending it to dealers even though I can do it myself as it’s got MoT insurance,I’ve changed the rear pipes myself last year as I didn’t want to risk them till March. Andy.
Hi Mike Good info for me and others thanks. 👍 I Would have used the supplied red ceramic grease all over but it ran out on the other side so it’s a bit of a mix. To be fair it can’t be worse than nil which Land Rover used on the pins, can it?! 3.0 SDV6 HSE L494 |
The drilled and grooved discs, I've found, can give quite a drone under braking. I've only fitted them to my D3 as it's a huge build, and a bit of willy waving never hurt anyone ![]() Redstuff ceramic pads are indeed low dust, and I rate them very highly, having run them on a little hot hatch, as well as the previous brake setup on my Disco, and I'm sure the 6 pots with Red pads will more than meet my expectations ![]() |
You'd be surprised... The differing metals cause galvanic corrosion, and attacks the pad seats of the calipers. Fine on a steel pad carrier, not ideal on a £600 Brembo caliper x2 In addition, the copper grease seems to attack and swell the rubber dust seals Stick to a ceramic based grease, we use both the Comma version and Mintex, depending on price/availability ![]() https://www.greaseexpert.com/brake-grease-vs-anti-seize/ |
This is the stuff I use on pads & it’s only a tenner on eBay for a 500ml tin which lasts me ages.
Hi Mike. Cheers for the info for indeed all of us. Had already read this article which is the detail on what you say 👍.
They have discontinued red for l494 front brembos. No idea why as they clearly will fit but I wasn’t happy fitting something not approved by the manufacturer. Gone with Hawk instead also ceramic. Will report back any concerns. Less meat on that LR pads that I do know. 3.0 SDV6 HSE L494 |
RRSporter,are the Hawke pads low dust as that’s what I’m after & if so best place to purchas3 them pls. Andy.
Hi Andy
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
Just to confirm, Hawk came from Cambridge Motorsport Parts, Letchworth.
