Home > General (L494) > Front pad change with Brembo
Page 1 of 5 12345>
ballast
Hi all - if you're thinking about changing the front pads yourself, it's very straight forward, but a couple of tips:
Before you start, get the pin replacement kit (OEM or LR). Getting the pins out inevitably messes them up a bit and it's worth replacing.
Get a pin removal tool (punch), it makes the job so much easier.
The pads push back quite easily - I was worried about damaging the disc, but it went very well!
I'm sure all this has been covered on here before by folk with lots more knowledge than me, but just thought I'd share my recent experience Very Happy
Chris
Post #594093 Fri Jan 31 2020 4:22pm
Dave-t
I’m also just starting the adventure so please carry on. Thumbs Up Joined the X5 45e club
1994 Defender 90 300 tdi
Post #594100 Fri Jan 31 2020 6:26pm
ballast
Fronts easy....
Wheel off - jack point just behind each wheel.
Two pins top & bottom - remove top first, but beware spring under tension - punch will replace pin so you can hold and remove - good Youtube video if you search too.
Remove spring (hooks under bottom pin); remove bottom pin; remove centre bolt (13mm socket).
As I say, pin removal tool is really vital - Laser do a cheap one that does the job, search on Amazon/eBay.
With two pins and bolt removed, gently ease the pads back using screwdrivers, but be careful of the discs.
Wiggle the pads free and refit doing the reverse.
Easy Very Happy
Post #594106 Fri Jan 31 2020 8:48pm
RRSporter
Just done mine. For balance an absolute pig of a job. Full LR service history. They had put the pins and pads in dry 🤡. No way were they coming out with any punch. A thorough bending of pins then restraighten etc eventually freed them enough to get out. One pad was still completely seized in caliper. Eventually pried out. Cheers Land Rover!!
So def buy pin kit for both sides and indeed sensor. Have fitted Hawk pads and Brembo low carbon discs. Filed caliper interfaces clean then lots of brake lube and also copper grease on pin interfaces.
Looking much better for it 👍🏼
 3.0 SDV6 HSE L494
Post #594112 Fri Jan 31 2020 10:35pm
Disco_Mikey
You shouldn't use copper grease on aluminium calipers Neutral
Ceramic grease is what should be used Thumbs Up
Post #594118 Sat Feb 01 2020 8:06am
Tyrefitter
Mike,while we are on the subject of brakes,I’m going to change both my fronts & rears & im thinking EBC discs & EBC low dust pads,which disc do you recommend as their is a few on the site,Drilled,Drilled & grooved as I’m wanting to match front with rears.Price wise isn’t a issue as I’m wanting to change them before MoT in March as I’m sending it to dealers even though I can do it myself as it’s got MoT insurance,I’ve changed the rear pipes myself last year as I didn’t want to risk them till March. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #594120 Sat Feb 01 2020 9:30am
RRSporter
Hi Mike
Good info for me and others thanks. 👍
I Would have used the supplied red ceramic grease all over but it ran out on the other side so it’s a bit of a mix. To be fair it can’t be worse than nil which Land Rover used on the pins, can it?! 3.0 SDV6 HSE L494
Post #594125 Sat Feb 01 2020 11:14am
Disco_Mikey
The drilled and grooved discs, I've found, can give quite a drone under braking. I've only fitted them to my D3 as it's a huge build, and a bit of willy waving never hurt anyone Laughing
Redstuff ceramic pads are indeed low dust, and I rate them very highly, having run them on a little hot hatch, as well as the previous brake setup on my Disco, and I'm sure the 6 pots with Red pads will more than meet my expectations Thumbs Up
Post #594132 Sat Feb 01 2020 1:45pm
Disco_Mikey
Hi Mike
You'd be surprised...
The differing metals cause galvanic corrosion, and attacks the pad seats of the calipers. Fine on a steel pad carrier, not ideal on a £600 Brembo caliper x2
In addition, the copper grease seems to attack and swell the rubber dust seals
Stick to a ceramic based grease, we use both the Comma version and Mintex, depending on price/availability Thumbs Up
https://www.greaseexpert.com/brake-grease-vs-anti-seize/
Post #594133 Sat Feb 01 2020 1:50pm
Tyrefitter
This is the stuff I use on pads & it’s only a tenner on eBay for a 500ml tin which lasts me ages.
Mike,I can only find green stuff & yellow stuff pads for the L494,I’m struggling to find the red one. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #594134 Sat Feb 01 2020 2:03pm
RRSporter
Hi Mike. Cheers for the info for indeed all of us. Had already read this article which is the detail on what you say 👍.
https://pagid.com/wp-content/uploads/2017/06/Copper-grease.pdf
Guess what I’ve already stripped them out, got myself high on brake cleaner 😂 and rebuilt with ceramic grease. More because I though those pins would corrode in again = nightmare!
This is what it now looks like. Ps should I be shocked that Land Rover installed the pad pins dry?? Do you normally reuse the pins and springs all being well? 🤔
 3.0 SDV6 HSE L494
Post #594135 Sat Feb 01 2020 2:08pm
RRSporter
They have discontinued red for l494 front brembos. No idea why as they clearly will fit but I wasn’t happy fitting something not approved by the manufacturer. Gone with Hawk instead also ceramic. Will report back any concerns. Less meat on that LR pads that I do know. 3.0 SDV6 HSE L494
Post #594136 Sat Feb 01 2020 2:12pm
Tyrefitter
RRSporter,are the Hawke pads low dust as that’s what I’m after & if so best place to purchas3 them pls. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #594137 Sat Feb 01 2020 2:16pm
RRSporter
Hi Andy
Info came from Dave B on thread below. Yes low dust ceramic. High carbon brembo discs as he suggests too from Autodoc. Hawk are via chap on eBay (very helpful) or direct from him.
https://www.rrsport.co.uk/forum/topic52142-15.html
https://rover.ebay.com/rover/0/0/0?mpre=ht...2613614009 3.0 SDV6 HSE L494
Post #594139 Sat Feb 01 2020 2:47pm
Dave B
Just to confirm, Hawk came from Cambridge Motorsport Parts, Letchworth.
I've also just fitted the Brembo High Carbon Discs to my Disco 4 Commercial, but couldn't get Hawk for this, so using D-TEC Ceramic which came from MPS Trading, Hellingly.
So far so good, and MPS are very helpful.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #594143 Sat Feb 01 2020 3:30pm
Page 1 of 5 12345>
