![]() | Home > In Car Electronics > No Harmond Kardon Logic 7 On RRS Autobiography 2012 |
Firstly are you sure it is a genuine A/B as there are a lot of look a likes out there, I have not seen anywhere in the audio setting on mine to turn the Logic 7 off but to be fair have not looked as makes no sense to me to turn it off. Also has the front door speakers got the Logic 7 logo on them as they should have.
Irving Member Since: 15 Jan 2020 Location: London Posts: 17 ![]() ![]() ![]() |
Thanks for the info. It is very interesting. I don’t think the speakers do have ‘logic7’ written on them but there is a sub in there.
My Autobiography has A/B on the log book as well, it also has Autobiography Sport embossed on the headrests along with it on the door card trims as well. Odd why anyone would spec. it without the Logic7 that's if you even could.
Yeah this is my thinking. I can’t work out why or how it could be this way. That being said I don’t think it has ‘autobiography’ on the seats. I need to double check those bits now.
Have you registered with L/R's Topix? it's free to register and if you input your Vin. number it should show you the build spec on your car, although these are not always 100% accurate but would think it would confirm if it is a A/B or not.
I haven’t no. That is very helpful, thanks.
Vin No. will be in the log book, or to the left on tag fixed to front slam panel under the bonnet, if you really wanted to look it's also stamped on chassis below drivers door, |
Perfect thanks.
I am not a solicitor but if it was advertised as a Autobiography and you bought in good faith on that basis I would certainly go back to the dealer, if it is not what was advertised then surely that could be classed as false advertising and consumer rights may come into effect.
Yeah. Luckily my brother works in car sales and you get 30 days under the consumer credit regulations or something and if they don’t agree you go to the ombudsman and they are very tough on dealers.
I think initially you need to confirm whether it is actualy a genuine A/B or not, then go from there. Don't know if it helps at all but this is what is shown on my V5 the "A" on the end I believe refers to automatic.
It definitely isn’t unfortunately. I checked. It’s an HSE but my order form with the garage says autobiography. |
If you like it, tell them to knock £5000 off and you’ll keep it and then upgrade the stereo yourself if you want it. I prefer the L7 to stereo every time. 2019 5.0 SC SVA (Current)
Yeah, well they offered me 1k and I said that wouldn’t even cover a stereo upgrade, so no thanks.
