Home > Wheels & Tyres > 275/55/20
Hamtheman
South Africa 2011 Range Rover Sport Supercharged Alaska White
275/55/20
2011 L320 5.0SC, I'm looking at 275/55/20, any idea if they will fit without rubbing?
Post #593530 Mon Jan 20 2020 8:41am
knwatkins
No idea concerning a 275 width with a 55 profile.
However, a 255 width with a 55 profile will fit fine. I have these on my L320. Kev
Post #593531 Mon Jan 20 2020 8:45am
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
Re: 275/55/20
This chart will help you , but our RRS have smaller wheel arches than Disco 3-4 and more clerance uses
http://johnsonrods.com/johnson_rods_3_004.htm TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #593548 Mon Jan 20 2020 5:52pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Below is a pic of my 200 RRS with 275/55R20s.
They fit but the rears will rub on the wheel arch on the leading edge under compression if you don't raise the Sport. Also the fronts may rub on the rear of the wheel arch under compression and full lock.
I've raised mine 10 or 15mm with an IID Tool and have no issues.
Cheers 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #593558 Tue Jan 21 2020 5:12am
Guy, 275/55 x 20 are around 80mm larger diameter then standard wheels with raising the suspension another 10-15mm means you have raised the height of the vehicle somewhere in the region of 45-50mm, has this not effected the stability of the vehicle at all as you have raised the centre of gravity somewhat?
Post #593564 Tue Jan 21 2020 8:01am
Guyzer73
Col,
To be honest I haven't noticed anything, but then I don't push the Sport through corners like a sport's car.
For my day to day driving I find the ride perfect, suitably firm and comfortable. Perhaps the ACE system assists in mitigating the additional roll due to the higher center of gravity.
Either way, I have no loss of confidence in the Sport's handling.
Post #593565 Tue Jan 21 2020 8:15am
Hamtheman
Thanks all, I will then probably got for the 275/55/20. I will lift her with my IID tool to avoid clearance issues. I would be happy with 255/55/20 but tyre selection here in that size is limited, and I am after more sidewall
Post #593572 Tue Jan 21 2020 12:10pm
RainHard
South Africa 2009 Range Rover Sport Supercharged Alaska White
Cooper Discoverer AT3 XLT 275/55 R20 - beautiful. Rubs (but just a bit). LLAMS fitted . 1st setting is 15mm lift - all sorted (low enough to be stable but high enough to take out the rubbing). Seriously not 100% needed though.
Post #631489 Wed Mar 08 2023 7:37pm
