Home > Maintenance & Modifications > Dr Tranny & the Dodgy Torque Converter |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Now there is another method for adding it.
Sun Nov 17 2019 2:08pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I've just paid £1,200 for supply and fitting of a new OEM torque converter. The same company quoted £2,100 for a recon box. Some of the best money I've spent on the car - smooth as anything. They are a bit too far from you, though... |
Sun Nov 17 2019 2:42pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Yeah, I did think about just getting a new box, but Mrs Cornish needs a new(er) car (two door soft tops are not easy to get grandhildren in the back!), so thought it would be worth a go |
Sun Nov 17 2019 9:48pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
What a good idea! Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Thu Nov 21 2019 6:48pm |
it's the level plug on the side, just incase anyone else was thinking of following this |
Fri Nov 22 2019 12:54pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
How much do you add? Conflicting info on the Dr Tranny website. Steve
Fri Nov 29 2019 10:18pm |
I bought two tubes, but only added one. This seems to have worked fine. |
Wed Dec 18 2019 2:53pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
The big question is how did you drive the RRS to get it on both ramps they are good but that is above and beyond |
Wed Dec 18 2019 4:59pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Did you think about a Megaflush? Visitor from fullfatrr.com
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
I added two tubes a few years ago. Curedthe shudder completely.
Wed Dec 18 2019 10:12pm |
It was quite easy really. Raise the suspension to Off Road height, put the ramps in front of the drivers side wheels and drive up 'em! I used to use low-range, but it can be a bit jerky as the gearbox bites.
Yep, I had it done about a year ago, it helped a little, but not much. |
Thu Dec 19 2019 8:38am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Dr Tranny doesn't cure the problem it just helps mask the symptoms. The torque converter lock up clutch will need replacing as it gets contaminated with gunk in the transmission fluid. Obviously if you have a flush after adding the Dr Tranny, you remove the Dr T and the symptom comes back.
Thu Dec 19 2019 9:24am |
Just put one tube in mine as a precondition, had mine two months it had a slight judder under acceleration when I test drove it and the dealer said he would sort it out. A Land Rover specialist done a fluid change for them and it’s been fine but I want it to stay that way so I popped one tube in (got two tubes so may do another change in the future) it certainly has smoothed the low speed gear changes out markedly though I haven’t driven that far yet. Steve
Fri Jan 17 2020 10:37pm |
Wayne is spot on with this advice. Have it done as a part of a preventative maintenance programme before any symptoms appear then at regular 50K intervals Had my Full Fat Megaflushed by Bodsy at 85K. No symptoms before or after. That’s what you want Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Sat Jan 18 2020 8:07am |
