![]() | Home > In Car Electronics > Tesla Style Screen 10.4 - Project |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
I have ownership, I have the original LHD scan, tidied up and flipped RHD cad files ready to print. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Aha, smart man |
I have popped a message to Martin in regards to selling through the forum as I don't want to step on any toes, once I get a response I will PM you the details |
C9LFS Member Since: 18 Apr 2017 Location: Kirkcaldy, fife Posts: 22 ![]() ![]() ![]() |
Have to say that looks amazing! I did a similar swap in my e70 X5 for the android 10.25 but the issue I had was the sound quality as the system uses the aux same as this is there no way to get the android side to talk to the car I have logic 7 and am considering this also as love the car and this bring them right up to date |
also interested in the digital dash from ffrr what sort of cost and modification is involved with Both these mods.
I might have a solution for that, will keep you posted in the next week ![]() |
The dash, buy a TFT instrument cluster, remove your analogue one. Read the chip in the analogue one, modify the file to work in the TFT one. Chop some plastic off the TFT and very very careful install. Use a gap tool to change the revs if it bothers you its at 7k. Lots of info over on the disco4 forum. The screen, is plug and play apart from the panel which I had to get custom made and 3D printed, then covered in leather from some seat covers I had. |
does the centre of the dash still display the same? the turn by turn nav and car settings etc.
"does the centre of the dash still display the same?
many thanks for taking the time to reply, thats given me food for thought. |
Poppy Ann Member Since: 05 Feb 2020 Location: Mansfield Posts: 1 ![]() ![]() |
can you do better? if not don't complain. For me the photos supplied were great I am in the process of doing the same to my discovery 4 I ordered a radio from Banggood as normally i have not been charged the import duty on any item i have ordered along with no VAT also they have their own priority mail delivery which is mostly free. many thanks for all the work you put into this project. |
On that note here is an update on the issues I was trying to solve:
Add a range rover boot animation - Done, Range Rover Logo now fades in/out on launch Change the car image to a black autobiography - I have finally found this image location and will look to replace Spelling issues - Now changed to Connected rather than conneted Remove the top bar and replace with custom bar - I can now do this but I need to get my launcher in a good enough position to remove the top bar completely, work in progress Stop Spotify being killed when going into system apps - Done but it still mutes Spotify when you go into the original car info screen, when you come out the music comes back on. I have asked the tech community on this but no one can figure out why this happens. But only a very minor issue now Overall I have had to get very involved in the code to make the changes I have needed, adding to white lists, unpacking .apk files and changing code and packaging them back up, rooting the unit to be able to do all of this. If anyone does want to attempt the same I'm happy to give some pointers, once all the software changes are made I will put up a video of everything working. |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Now now, no need for that, seems like your the only one complaining. If you had just read a couple more posts you would have seen there was a problem uploading the photo's to the original post
did you ever manage to get the sound to come through without plugging into the aux?
