Home > In Car Electronics > Amp swap and ccf edit
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
I’m going to put this here people. Although a ff owner it seems the l494 owner’s are more into modding.
I know people on here have swapped to premium speakers and amps from the meridian range as I’ve read pretty much every post I can find on the subject.
What I can’t find is if you do swap say the 380w meridian amp for the premium meridian. Is it true you have to edit the ccf before you hear any improvement in sound? This may sound a stupid question. But! I can’t see a ccf edit making any difference to the power the amp is putting out. Surely the ccf edit is more if you want to have the surround option on the screen or something like that. If this is the case then I will go ahead with the mod and deal with the ccf stuff last.
I can’t understand how the ccf would stop an amp from producing the wattage it’s made to? Maybe someone on here can shed some light on the subject? Cheers in advance.
Post #593209 Sun Jan 12 2020 12:26pm
Brit Plumber
I think there’s more to it that just what the power output is. The CCF edit tells the FCDIM what AMP is installed so that it can talk to it. From what I’ve heard, if you don’t do the CCF edits you will get a configuration DTC and may not have all speakers working. Depending on what entertainment you have, there could be upto a dozen edits required. When I was involved in a basic to premium upgrade with famousfive on the Disco forum, it required about 15 edits and we still couldn’t identify which was needed for the FM to work correctly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #593253 Mon Jan 13 2020 2:58pm
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
Kind of hijacking the post lol
I've had a new CJB installed and ever since the sound just seems different....do you know if anything audio related needed to be re installed? RRS TDV6 2010 Smile
Post #593254 Mon Jan 13 2020 3:30pm
felstmiester
thanks. I’m not about to mess about with something I know nothing about. Swapping amps & speakers, well anything mechanical is fine. But when comes to editing stuff diagnostically and it could seriously go wrong I don’t wanna know. The ff will go up for sale in place for a better specced one Thumbs Up
Post #593258 Mon Jan 13 2020 5:08pm
