Home > General > Tyre Pressure 21"
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Tyre Pressure 21"
Guys.
Apologies to what may seem a simple question. I have just replaced the 20" alloys with 21". Now typically I would look to see what the tyre pressure should be by looking on the drivers door. However these only give me pressures of 19 and 20". Would would be the correct pressure for 21" now?
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #592907 Mon Jan 06 2020 2:04pm
Dave B
I have 275/45 tyres, my local tyre company said 40psi, but a tyre fitter says 36 would be better, and that's what I use now. 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #592909 Mon Jan 06 2020 3:20pm
McFarTech
Thanks mate. Is that 36 front and rear? ===========================================
Post #592910 Mon Jan 06 2020 3:22pm
Dave B
Yes 2010 3.6 TDV8 HSE (Gone)
Post #592911 Mon Jan 06 2020 3:38pm
McFarTech
Thanks mate. Will pop out later and change it. I’m currently on 33 front and rear ===========================================
Post #592916 Mon Jan 06 2020 4:00pm
Dave B
Just a thought, I have a V8 which is heavier than your V6, so possibly 33 at the front would be OK, definately 36 at the rear.
Hopefully TYREFITTER will be along shortly to confirm.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #592918 Mon Jan 06 2020 4:46pm
Tyrefitter
I’m running 47 rears & 40 fronts,I was running 37 rears & 33 fronts but I’m on 295/40r22’s & it was a bit sloppy on cornering at high speeds & that’s the reason I’m now trying them with more air in them,I’m running them at the heavy load pressure that it recommends on the dash when you go into the tyre pressure recommendations.I hope this helps. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #592928 Mon Jan 06 2020 6:37pm
For some strange reason I run 34 front and 37 rear in my RRS1 with 275/45 x 21" wheels/tyres, found it rode and handled just fine for me.
Post #592934 Mon Jan 06 2020 8:16pm
scarey
33 front and 36 rear works for me..
Post #592949 Tue Jan 07 2020 8:12am
