![]() | Home > Technical > TDV8 3.6 RRS 2008 P0191-23 WONT START NO FUEL PRESSURE HELP |
Tobias275 Member Since: 04 Jan 2020 Location: kent Posts: 12 ![]() ![]() ![]() |
Also is there a way of raising the suspension without the engine running ? |
This is what the code brings up so try fuses to start |
the fuel fuse under the bonnet is ok power coming in and power coming out
Not 100% but with ignition on is there any pressure at valve or can you here pump start when key first turned on |
theres no pressure at the Schrader valve when initial ignition or whilst cranking, also i cannot hear the pump under the seat |
Start looking at the pump then and power supply to it |
if the pressure sensor is faulty would that stop the LPFP from firing up?
You never mentioned the injectors before |
apologies, i edited the post earlier to put the fuller picture as i realised people need all the info |
what else would you advise i need to check? |
make sure you have everything you took apart back in its right place as you say it was ok prior to you removing the injectors |
checked everything at the front is all connected, power to both sides of the fuse and relay working. no noise from the tank area on initial ignition so went to check the continuity at the pump.
Have a look at this may help |
thanks for the link, i checked myn and the tailgate door was programmed to open.
