Home > Technical > TDV8 3.6 RRS 2008 P0191-23 WONT START NO FUEL PRESSURE HELP
geoffsnook
You can change what it does so search maybe here or disco3
https://www.disco3.co.uk/forum/self-re-pro...ith+remote
Post #592984 Tue Jan 07 2020 8:02pm
Tobias275
England 2008 Range Rover Sport TDV8 Autobiography Zermatt Silver
Thanks again for the links, tried it several times but because i cant start the car it wont allow me to re program it.
was wondering whether i could put something down the filler cap into the tank to try and tap the motor incase its dried out due to being on a slope with low fuel?
looks like im going to have to get it recovered to a 2 poster ramp unless there are any other suggestions as to why all of a sudden the pump is not priming?
Post #593036 Wed Jan 08 2020 8:29pm
geoffsnook
Not 100% sure on this but I know under the bonnet on my Disco3 there was a fuel cut off switch in case it rolled over I’m sure they knock out the fuel supply so may be worth looking at that to see if you have one and if it’s been activated as you have been messing with the system other than that maybe the pump has been dried by trying to jump it Thumbs Up Thumbs Up
Post #593038 Wed Jan 08 2020 8:38pm
geoffsnook
Failing that have a look on disco3 or one of the guys on here for a specialist near to you from here they may be able to help you more there are a few around you Thumbs Up
Post #593040 Wed Jan 08 2020 8:52pm
Tobias275
thanks for the inertia pointer, found this thread https://www.rrsport.co.uk/forum/post441543.html
Post #593045 Wed Jan 08 2020 10:57pm
