Home > Maintenance & Modifications > Tdv6 2.7 inlet manifolds replacement
Fluff006
England 2008 Range Rover Sport TDV6 HSE Santorini Black
Hi there. I’m just looking for ideally a step by step on how to replace the inlet manifolds. Any specialist tools? Or any tips and tricks?
Post #592571 Tue Dec 31 2019 4:48pm
It not a 5 minute job.
you need to :
remove injectors
remove fuel rail
remove fuel rail mounting brackets.
then you can get to all the bolts!
The front timing belt cover needs loosening as there is a bolt behind there too Rolling Eyes
Could put a new timing belt on !
Post #592572 Tue Dec 31 2019 4:55pm
Fluff006
Thanks for the reply. At the same time the engine packed up it also said low coolant. If it has all caught fire in the inlets could it of lost the water through the egrs coolers? It all happened at once and on closer inspection the passenger side inlet. Is badly melted with lots of holes. The drivers side has a couple. Even the butterfly has a hole. So I’ve bought both manifolds. The butterfly. 2 gaskets. Egr blanking kit. Should that be all I need?
Post #592602 Wed Jan 01 2020 2:21pm
some would said change the injector copper washers.
Check the coolant level in the front of the tank to see if it's actually low
the Float for the sesnsor is a common failur on these
Post #592634 Thu Jan 02 2020 12:09pm
Disco_Mikey
If its an 08 car, you will need a software patch to allow blanking, or 2x new EGR valves
Post #592635 Thu Jan 02 2020 1:27pm
Fluff006
The coolant come up on the dash at the same time it happened and the bottle is dry. I haven’t put no water in incase it gets into the engine. Whether it’s even possible I wouldn’t know. Some one told me it could’ve sucked anything into the heads. Is this possible is there anything too look for when I get it down to the cams? It was still ticking over fine when it happened. Now it’s been stood for a couple months it won’t start. Would you be confident that the manifolds would be the cure or could it be possible there’s more damage you won’t see until it’s done? Cheers.
Post #592704 Fri Jan 03 2020 6:28pm
It’s worth changing the cam covers.
The add coolant and see if it leaks anywhere and try and start it.
Get battery in charge now. Before it’s ruined
Post #592706 Fri Jan 03 2020 7:18pm
Fluff006
Ok thanks for your help. I’m going to have a go tomorrow. I’m alright with spanner’s but never dealt with a big job like this. Will the injectors likely to be tight to get out or what other issuees could I have? Last thing I wanna do is break something off. Also is the software patch just to get rid of the engine management light? Cheers.
Post #592780 Sat Jan 04 2020 8:34pm
Injectors can be difficult
Twist them.
Post #592781 Sat Jan 04 2020 9:05pm
Fluff006
So I had a go yesterday. Only for a few hours. Ready now to undo injectors. Will the back ones on both sides come out past the plastic plugs. It’s like 3 big clips that seem to slide out so far that are packed with wires. Or do I need to remove these. I’ve got the battery of and all the plastic around that. It just seems I need to take half the engine bay out to get at anything.
Post #592899 Mon Jan 06 2020 12:12pm
rear passenger side is a pain.
can't remember if the loom needs moving. If it does, a couple of long flat blade screwdrivers, to prod at the back to unclip them.
A small thin screwdriver can be handy to stop them jumping back in
Post #592921 Mon Jan 06 2020 5:50pm
Fluff006
So I got all weekend on it now. Although I’m hoping a good day tomorrow will do most of it. How would I need to bleed the fuel system. I’m not changing the fuel filter as yet. Just want to see if this cures the problem first. Fuel filter will be a later date. So it’ll just be the rail and injectors to bleed. Thanks
Post #593099 Fri Jan 10 2020 12:39pm
One way I saw recently was to leave one injectors metal pipe (each side) slightly loose and then crank it over briefly until fuel comes out. The. Tighten
Post #593113 Fri Jan 10 2020 4:42pm
Fluff006
Thanks for all your help. I got it all back together today. Not a job I would wish on anyone. I’m half decent with spanner’s but when it comes to injectors an that I was a little worried. All back together. Bled the fuel system. Took a lot of winding over but it finally fired up. Left it running to clear and runs sweet as a nut. Egrs blanked. Only problem is a leak of pipe is leaking fuel. Half the nipple has broken off. Is this a replacement part or is it the whole line of leak offs I need? I’m holding myself back from driving it as it must desperately need oil the manifolds I took off has no plastic flaps left and holes in I can see through. Now to solve the water leak as that happened when the rest did. Bit strange.
Post #593215 Sun Jan 12 2020 4:18pm
Fluff006
Here’s pics.
Post #593217 Sun Jan 12 2020 4:19pm
