![]() | Home > For Sale & Wanted > [Wanted] L320 Autobiography Sport 5.0 supercharged wanted |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Try and find one after Vin No CA759577 2012 on as the earlier engines did have a issue with timing chain guide wear and rattle but after that they fitted modified guides etc. of course they may already have been done on earlier cars so might be worth checking, other than that engines seem to be pretty bullet proof. Not trying to put you off just though it might be helpful bit of advice or suggestion.
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Hi Col.
Hi Col.
If you Google LTB00474 should find a little more info. |
Thanks Col.
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
My car is sitting on the drive waiting to have chains done
And it’s a 2012 car 91k on the clock 61 AB 5.0 supercharged rocket
Out of interest does yours fall outside the Sport VIN. range? as at one point L/R said they had rectified the 3.0 crank/bearing issue when they obviously hadn't.
Cheers Col |
It’s 5.0 supercharged not 3.0 nothing wrong with the crank 61 AB 5.0 supercharged rocket
I think you may have misunderstood what I was asking, didn't actualy ask about the crank I asked if your car was in the Vin. range mentioned in the L/R technical bulletin relating to the timing chain tensioners, as later 2012 cars are outside that range. The reason I mentioned the 3.0L crank is at one point L/R said they had rectified the fault with that but hadn't back then, and wondered if the same situation applies to the 5.0L chain guides.
Hi ShooterNeil. Thanks for the reply. if they have to have the chains done as long as they get done so not to bothered if it falls under the recall. Just need proof it's been completed. Do you have any pictures of your sport. Thanks. Tom. Indus Silver / Santorini Black Roof MY16 Autobiography Dynamic Hybrid 354bhp. 22" Style 504 Alloys. Lunar Grey / Ebony Seats and Interior. Surround Cameras, Meridian Signature Reference sound system 1700watts, Adaptive cruise & Queue Assist, Blind spot closing vehicle , Adaptive Xenon Headlights, 4zone Climate, infra-red reflective glass, deployable side steps, and a few more extras ....... |
Sorry meant to ask what colour is your sport? My son Ross doesn't really want black or white but depends on condition specs etc then he might make a compromise |
Only one at the moment had it in June it’s got cream leather it’s surprising how clean it has stace as I am a carpenter so jeans are normally dusty
Tom, if they are of any use or interest File 1 & 2 in "My Gallery" are sales and price list brochure's for the RRS1 2013 cars which will give you a idea of the spec. and options which were available on different models, also have a 2011 price list somewhere. I think you can download them from there as well if you did want them.
