Home > Faults & Fixes > 2011 Range Rover Sport HSE front fuse location |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Fuse 52 20amp (yellow) behind lower glove box passengers side.
Thu Dec 26 2019 9:03pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Get a dedicated hardwire kit and use the piggy back fuse holder as Col suggests. If you get the dedicated kit it will supply the correct voltage to the dash cam.
Fri Dec 27 2019 3:23pm |
I did initially mean fuse 52 is the one for the front cigarette lighter, but Oldandconfused is right with 52, when I hardwired dash cam used 52 as Aux feed and 48 as Live feed, I also connected two wires to each of the piggy back fly leads so had a spare pair of wires if wanted to add something else at a later date that need a aux and live feeds. Use long nose tapered pliers to remove fuse, the tool supplied in fuse box is absolutely useless.
Fri Dec 27 2019 8:26pm |
