![]() | Home > Faults & Fixes > 2011 Range Rover Sport HSE front fuse location |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Fuse 52 20amp (yellow) behind lower glove box passengers side.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Get a dedicated hardwire kit and use the piggy back fuse holder as Col suggests. If you get the dedicated kit it will supply the correct voltage to the dash cam.
I did initially mean fuse 52 is the one for the front cigarette lighter, but Oldandconfused is right with 52, when I hardwired dash cam used 52 as Aux feed and 48 as Live feed, I also connected two wires to each of the piggy back fly leads so had a spare pair of wires if wanted to add something else at a later date that need a aux and live feeds. Use long nose tapered pliers to remove fuse, the tool supplied in fuse box is absolutely useless.
