Home > Technical > RR sport - CRUISE CONTROL issue |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
The Adaptive Cruise Control sensor is not in the bumper strip with the parking sensors. It is above that (and just above the number plate) recessed in the lower air intake towards the passenger side of the car
Wed Dec 18 2019 7:35am |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 |
I mean you would find it very hard to identify any damage so I would be very surprised if this was the cause from the little knock. N
Wed Dec 18 2019 10:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Is this on your SVR? The sensor is likely in a different position to the one Eaters has shown which is for the original RRS ACC sensor. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 19 2019 9:19am |
Yep on the SVR
Thu Dec 19 2019 12:39pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Yep - would expect the anti-rear-ending to be based on the same forward facing radar sensor as the adaptive cruise (certainly was in my Skoda) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Dec 19 2019 1:01pm |
Jet washed the car thouroughly but still the goddam cruise and intelligent emergency braking not working
Mon Dec 23 2019 11:19pm |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 |
Where have you installed your dashcam?(you mentioned it in another thread) If behind the rear view mirror, try turning it off and see if that resolves it. I had to place mine to the left of the mirror mount rather than underneath it as it interfered with my ACC and high beam assist. |
Mon Dec 23 2019 11:30pm |
So I didn’t have the issue on install of the dash cam
Mon Dec 23 2019 11:35pm |
Mine didn't interfere on install, only happened after a while. Went to the garage as I couldn't find the problem, they turned the dashcam off and everything worked again straight away.
Mon Dec 23 2019 11:39pm |
Thanks Gerd..will try today ... is it the actual dashcam signal or the obstruction that was causing it ? N
Tue Dec 24 2019 9:15am |
It seemed it was the signal for some reason, as though the sensor in the windscreen is directed downward, therefore when mounted below something from the dashcam interferes with the signal. When mounted to the left and higher it seems as though it doesn't block the signal. Could be complete BS, just know it worked for me. |
Tue Dec 24 2019 10:05am |
Disconnected it and sadly still comes up
Tue Dec 24 2019 11:55am |
Tue Dec 24 2019 12:01pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Had exactly the same thing happen in my 2007 TDV8 two nights ago saying cruise not available never had any problems before got in it today & it's working normally again any ideas as to why ? |
Thu Dec 26 2019 7:10pm |
